- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
