- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 404 Not Found
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 404 Not Found
@AdamGar wrote:
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.
This can happen if you have multiple IP networks.
Is your Orbi configured as Router- or AP Mode?
If in Router Mode, is your ISP router bridged or is it also functioning as router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
FYI, Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem as mentioned above but I am a bit tech naiive and I do not know how to check the things you have suggested.
Regards
Kerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8
Look at the result printout, If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. 🙂
Private IP addresses are usually something like 192.168.x.x or 10.x.x.x.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So if you are in a double NAT condition, you have a couple of decisions to make as to how you will resolve the problem.
The end result is having only ONE router in your local network.
Your cable modem apparently has a wireless router built into it so that is one router, and your Orbi is another.
The first question you have to answer is "Where do I want my routing functions to be performed?" Either Orbi, or your cable modem/router combination. There are drawbacks and benefits to each course of action.
In a perfect world, Orbi would handle all routing functions and your original cable/modem would handle none.
If the answer to "Where do I want my routing functions to be performed" is in the original cable modem, you merely have to put orbi in AP (access point) mode and you are effectively done. In this case I would also turn off any wireless functions of the original cable modem and let Orbi handle all wireless communications while the original device is handling all routing functions.
If the answer is that you want Orbi to handle all routing functions, there are other decisions you have to make.
Can your ISP provide you a replacement cable modem without a router in it? (This is simplest course of action)
If not, Canyou bridge the original cablemodem/router combination to "turn off" routing functions so that Orbi can handle them?
If not, can you configure the original cablemodem/router combination to allow Orbi to work within what is known as the DMZ.
So each of these decisions will drive actions.
What is it you want to do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KerryBastow wrote:
This is what I got
@KerryBastow So this shows that you have double routers: the 10.0.0.1 is the Orbi and the 192.168.1.1 is the ISP router.
You need to keep only one of those routers.
As @Chuck_M mentioned you have 2 options:
1. The easiest option for you is to keep the ISP router as the router and change Orbi to AP Mode. You can do this by logging in to Orbi (use browser to access 10.0.0.1 and enter admin as user and the password) then do the follow the links below:
2. The other option is to change in the ISP router as @Chuck_M explained above.
The difference between the two options is which box you want the router functionality (DDNS, VPN, Parental COntrol,...) to be provided: by. Orbi or the ISP router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
Regards
Kerry
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much for your help guys, however, when I type in 10.0.0.1 it won't connect and says it has timed out????
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I get to command prompt????
- Mark as New
- Bookmark
- Subscribe
- Permalink
The same command propmpt that you used earlier when you did the tracert command, remember?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Click bottom left in windows next to windows symbol where it says TYPE HEAR TO SEARCH
Type CMD
Hit enter
voila!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
was that a screenshot from the command tracert 8.8.8.8
?? Try again please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KerryBastow It's strange that the PC is pointing to 192.168.1.1 as the gateway while the tracert showed that Orbi should have 10.0.0.1.
Can you please repeat the tracert that you did before from the same comuter. Here is what you got earlier:
If this is still true then it seems that your computer is getting it's IP address from the ISP router and not from Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
@KerryBastow wrote:
This is what I get:
- Mark as New
- Bookmark
- Subscribe
- Permalink
At the beginning of this post you mentioned you have Frontier and a Frontier provided wireless router.
What is the make/model of that wireless router? This is about the 5th time in this thread you have been asked this question and it is key to getting your problem solved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
