Orbi WiFi 7 RBE973
Reply
Orbi RBR50 on V2.5.0.38 no longer shows attached devices after changing IP range
bbender716
So I'm trying to assign a static IP for a raspberry pi. I originally assigned it using the IP Reservation panel and assigned, 192.168.1.97, rebooted, and then when I would connect the pi to the network, the network went down. I then read another thread where someone recommended changing the range to 192.168.1.100 - 192.168.1.200 so I changed the IP range to that.
Now the network comes up, but every time I try to load the Attached Device page it hangs, and if I try to change the IP range back to the original range, I get a:
"400 Bad Request
This server does not support the operation requested by your client."
Displayed. Any help would be appreciated!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
SW_
Prodigy
Prodigy
Re: Orbi RBR50 on V2.5.0.38 no longer shows attached devices after changing IP range
v2.5.0.38 was bad/pulled from NG support website.  The new attached device regconition feature has since been fixed in the latest firmware version 2.5.1.8.
Message 2 of 4
MCO79
Tutor
Im on 2.5.1.8, doesn't work for me. I have a new thread going
Message 3 of 4
Guru
https://community.netgear.com/t5/Orbi/RBR50-no-longer-showing-Detected-Devices/m-p/1868799/highlight...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 576 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
