Orbi WiFi 7 RBE973
Reply
Orbi rbr50 router magenta
Cde77
Follower
I have to constantly reboot the router to fix this magenta light. I've rebooted 4xtoday after working from home. All problems started after I received a software update a couple of weeks ago. Any suggestions on how to fix? Seems like it impacts mobile phones and iPads more than desktop.
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: Orbi rbr50 router magenta
Have you tried to change your Ethernet cord going between the modem and router?
DarrenM
Message 2 of 6
Dustin278
Apprentice
When my router is magenta I reboot my modem which fixes my problem.
Message 3 of 6
cbrutosky
Since upgrading the firmware to 2.0.0.74 I have been experiencing trouble with the router.  In the past week I have had to reboot the router because it has a solid magenta light.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 4 of 6
BillYoung
Luminary
Dustin278:
The only time I have seen a magenta ring on my router is when the modem is out.  Once the modem comes back, the magenta ring goes away.
BillYoung
Message 5 of 6
Dustin278
Apprentice
Yep that's exactly what I said above.. I just restart my modern then it's fine..
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1411 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
