- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi with fios
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi with fios
I have Fios. When using their router I get 900Mbs both directions.
When using Orbi I get about 500 down and near 900 up.
Why the big difference?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #3
Try a factory reset and set up from scratch with the Orbi, be sure to not enable QoS, Traffice Meter or Access controls, Circle.
Try testing with IPv6 disabled or enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
Any progress on this?
Please give feed back on questions presented...
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
Yes - You don't fully understand the issue. I dont want to use the Fios router. All your solutions state using their router.
All works great less half the speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
You'll need to contact the ISP to check to see if there router can be removed from the mix. Some ISPs require the use of there router. Options were given in these cases. If you can remove there router, then the Orbi can be used in router mode.
How are you testing the speeds? wired PC and web browser or speedtest.net app? Try different browsers?
Try disabling IPv6 if it's enabled.
Try directly connecting a wired PC to the ONT and speedtest there.
Try a factory reset on the Orbi router and setup from scratch, this time, don't enable QoS, Traffice Meter or access controls after setting it up. Do a speedtest first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
see below..... thanks
Different browsers, same speedtest, different results (half the speed), but consistent.
It is.
950mbs
Will hold off on this as it sounds like a guess and not based on facts / histroy - as I have three remote nodes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
You can do a search here in the forums if you need to find history.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
I have found mutiple issues on this topic back from 2017 with no solutions.
https://community.netgear.com/t5/Orbi/Orbi-cuts-download-speed-in-half-Upload-seems-fine/m-p/1464401
https://community.netgear.com/t5/Orbi/RBR50-wired-speeds-cut-in-half/m-p/1634162
https://community.netgear.com/t5/Orbi/Bandwidth/m-p/1161882
Outside of a reset I seem stuck. Power cycle is same issue.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
Try the suggested reset on the router.
I got this last year with my CBK40 system. Only difference is the built in modem from the RBK systems:
I presume the RBK50/40s should be seeing same results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
Thanks!
- What speed do you get when you do the Orbi built-in Speed Test?
- Did you have any other wired devices connected to Orbi when you did the speed test from the PC?
- Do you have wired backhaul to a satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
@timc166293 wrote:
Yes from router
No just single PC
Fiber
Thanks, my questions were as follows:
- What speed do you get when you do the Orbi built-in Speed Test that you can find here in the web GUI:
You can also find the same testing in the Orbi phone app.
- Did you have any other wired devices connected to Orbi when you did the speed test from the PC? Anything else connected to the LAN ports in the router or the satellite?
- Do you have wired backhaul to a satellite? Is the router connected to the satellite(s) using Ethernet cable or wireless?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fios
Yes Web GUI and through orbi app and speedtest.net. All consistent.
Test when no traffic but see 60 devices or so connected; sonos, PC, iphones, TVs, etc.
All remotes are wireless, but we are testing from orbi router up-stream. I am confused why this question matters.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
