- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK 753 constantly drops connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use the Fios quantum gateway for internet/tv/phone
Any suggestions would be appreciated; I’m at my wits end
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK 753 constantly drops connection
@ajbecker8 wrote:
After the change it worked fine for just over a week, but now back to same issue of constantly dropping. Sometimes just unplugging it solves the issue but other times it doesn’t and hours later it will just randomly connect. It’s beyond frustrating. If I switch back to the Fios router that works fine (minus the dead spots which is why I bought the Orbi!)
Do you have both WiFi systems active at the same time?
(My practice has been to give every new WiFi system exactly the same SSID/password as the one it is replacing so that none of my devices have to be reconfigured and that I can "go back" just by swapping the units.)
Can you be more specific about what is "dropping".
- The WiFi SSID disappears?
- Devices connected to the Orbi remain connected, but no longer can access the internet?
- What does the Orbi web interface administrative web page show about the connection and Attached Devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve tried having the WiFi radio turned off and on on my fios, no difference either way.
I’m not familiar enough with the Admin pages and can only access them when I have a connection. Right now there is no connection to Orbi so I can’t go to admin page
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a difference between connection to Orbi and internet connection.
Fios assigns an IP address to the Orbi router (in AP mode, but we still call it the 'router').
If something is connected to the Orbi WiFi (even if it says "no internet") a web browser should be able to open the Orbi router by IP address, i.e. http://<ip of Orbi>.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Number of satellites 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi system relies on having a good connection from the host router or ISP modem/ONT. Make sure that these devices are working well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Never had a problem with a stable internet connection from it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the RBR in router mode with the IP address the RBR gets from the G1100 input in to it's DMZ. Does problem still continue?
Try powering OFF the RBR and G1100 for 30 seconds then back ON.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
@ajbecker8 wrote:
It’s the Fios quantum gateway g1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did notice a firmware update and updated this morning. Orbi rebooted and haven’t had an internet connection through the Orbi since
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, is RBR still in AP mode or back to router mode after FW update?
@ajbecker8 wrote:
RBR was in router mode when all issues began. Tried factory resetting it multiple times with support. Support then recommended to put it in AP Mode because of a conflict with IPs with the Fios router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also I cannot remove the Fios router as it handles the tv as well
Either my unit is defective or the Orbi does not work well with Fios
- Mark as New
- Bookmark
- Subscribe
- Permalink
