- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK33 benefit of adding ethernet satellite RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought RBK33 system one year ago (RBR40 router, two RBW30 satellites). Noted the satellites do not have ethernet ports. My work laptop is connected to satellite via WiFi. My VPN connection to work often drops and reconnects. Will adding RBS50 satellite (with ethernet port) and connecting to laptop via Cat5 cable help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK33 benefit of adding ethernet satellite RBS50
Possibly.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
One can add a RBS20, or RBS40v as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
current satellite RBW30 just updated firmware to 2.6.2.2. Satellite is about 50 ft away from router. Satellite is about 15 ft away from laptop. Home is ~2300 sq ft.
Laptop is connected at 5GHz but setting is auto.
ISP is Spectrum. Modem is Technicolor E31T2V1 which is DOCSIS 3.1 compatible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might try RBW a bit closer to the RBR. Maybe 40feet and see if this helps any...
- Mark as New
- Bookmark
- Subscribe
- Permalink
would anybody know if adding RBS20 or RBS40 with ethernet cable from satellite to nearby laptop would be better and more stable than wifi from existing satellite? And is RBS20/40 a better match since the base router is AC2200 not AC3000?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before trying that, why not hardwire your pc/laptop into the router and see if its stable with your vpn?
If that is the only device with issues, I'd check to ensure hardwiring helps before investing in another satellite that we can't 100% say will help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try it thanks (although the router is 70 ft away).
If the performance is better (no VPN drop) when connected via ethernet direct to router, should I expect the same performance if I add RBS20 and connect to that satellite via ethernet cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the performance is better (no VPN drop) when connected via ethernet direct to router, should I expect the same performance---the same performance? no. but its worth trying. You could also try moving your rbs to the midpoint and see if it helps at that point. There's several different things you can test before buying a satellite to help ensure it'd fix the issue. if I add RBS20 and connect to that satellite via ethernet cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks. would you expect performance would be better with an additional (new) RBS20 satellite connected to laptop via ethernet ... compared with current wifi connection to current satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a laptop. My first experiment would be to move the laptop to the router and plug it in.
There are so many things that can interfere with VPN connections that it is pure conjecture as to what effect adding another satellite (with an ethernet jack) will accomplish. One thing for certain: if the VPN connection is flaky connected directly to the router, then nothing done with satellites will improve it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks very much!
- Mark as New
- Bookmark
- Subscribe
- Permalink
So temporarily moving my laptop into my wife's office and connecting via ethernet into the router is far more stable - only one VPN drop in 20 hr. Back to my previous question - will adding a satellite RBS20 or RBS40 and then connecting my laptop via ethernet to the new satellite make a difference? (I can't move the router and don't want to drill holes and run a 100-ft ethernet cable through the attic.) Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We can't say 100% if it'll make a difference. theoretically it should but application is different.
All we can say is buy it from somewhere with a generous return policy so if it doen't help, you can return it.
