- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK40 v2.2.1.210 Satellite drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RBK40 was setup more than a month ago and it was updated to latest firmware by that time to 2.2.1.210. Then I had to factory reset my router twice to work properly. Issue is that devicess connected to Satellite will not have any internet after around 7-10 days from fresh setup of router. Everyone at home frustated with this issue and asking to go back to old router R7000 which didn't have many issues. I thought it was an upgrade, but seems like pain and losing trust on netgear.
Currently I am turning off the satellite whenever the issue appears until my next factory reset.
I read many issues in this community about orbi RBK40. But couldn't find an issue similar to me.
I have unchecked all these settings as I read they can cause issue
Enable Daisy-Chain Topology (i have only 1 satellite)
Enable Implicit BEAMFORMING
Enable MU-MIMO
Enable Fast Roaming
On orbilogin portal, connection to satillite shows Good.
Does anyone has similar problem and have any solution for this? I appreciate your help.
I see a new FW version 2.3.0.28 available now whcih I am going to update manually (orbilogin portal says no new firmware avaialble) and try that.
Also, is there any tool or import method to setup IP reservations in bulk rather than 1 by 1? I know settings restore feature there, but netgear community/support doesnt recommend that when upgrading to newer FW version.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear support replaced the satellite with other one. New satellite didnt work plug and play. Had to reconfigure both router and satellite together. But finally it works.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK40 v2.2.1.210 Satellite drops internet
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem: Centurylink | Actiontec C2000A (on transparent bridge)
Model: RBK40
Mode: Router
Home SqFt: 3500
Distance: Router in Basement and Satellite on Main floor. Distance would be about 20-25ft.
Channels: Auto. I checked thru wifi analytics app and the channels Orbi used and they NOT overloaded by neighbors' routers.
Security options: WPA2-PSK [AES]
Beamforming and MIMO: I tried these once before doing factory reset. But no change in issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Distance between base and satellite maybe too close. try to move the satellite a bit farther out. I would test with just the Orbi base to see if the problem continues.
Try manual channels and enable Beamforming and MIMO.
@rsquarev1 wrote:
Model: RBK40
Mode: Router
Home SqFt: 3500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using your web browser, go into your web gui (probably 192.168.1.1) and add to it /RST_conn_status.htm
The address will look like this:
http://192.168.1.1/RST_conn_status.htm
What are your DNS servers and your lease obtained/expires times?
And while you are in there, please let us know the NTP settings under
http://192.168.1.1/adv_index.htm
I suspect you have the lease renewal issue which has a simple fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for confirming the ISP modem info.
Let us know if any of the suggestions helps...
Model: RBK40
Mode: Router
Home SqFt: 3500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is link on changing lease time... which sounds to me like the issue you are having.
- Mark as New
- Bookmark
- Subscribe
- Permalink
connection time now shows 19:12:00. I didnt check when it was a problem.
I use google dns servers. 8.8.8.8/8.8.4.4.
if the lease issue, shouldnt router also lose internet? I am having problem at satellite. NTP settings are here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My bad, I read this as network wide....
Disregard the above.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you give a list of the types of devices that would connect to that satellite?
Any speakers? Any other devices that may carry with it their own network? (Example: Sonos)
- Mark as New
- Bookmark
- Subscribe
- Permalink
This may not be pertinent, but when I setup my Orbi, it wasn't until I logged into the management console on PC that I spotted a slick notification indicating the subnet of the router was changed from 192.168.1.x to 10.0.0.x. Until that change was made, most of my devices were unable to access the internet. This matters if you have an ISP like ATT which uses the former as the root subnet on their gateways.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is very pertinent....
Sounds to me like you may be in a double nat condition.
Your Orbi is connected to what? (make & model please)
Is your Orbi in AP or Router mode?
Can you please from a pc on that network do a TRACERT to 8.8.8.8 and tell us if the first two lines are private IPs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds to me like his Centurylink modem may not really be in bridged mode OR he still has the wifi turned on in it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anything is possible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Devices connected to satellite are iPhone X, Galaxy Note 8 and brother printer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So then the question has to be is it the backhaul that is not making it or is there something wrong with the satellite itself.
You could temporarily test this (if you had a good length of cat5) by hardwiring your satellite to the router and see if that clears up the disconnects. You would know that for some reason the signal from the router isnt making it -- perhaps you are just on the fringe of the range based on construction materials of your house.
If the problem didnt clear up, you know it has to do with the satellite and wifi radios.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a reset with the Satellite. Do this while in the same room as the router. See if the satellite will reconnect and gets a BLUE light on top. If so, take it back to the remote location and turn on. Still get a BLUE light on top?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated the firmware to 2.3.0.28. That didnt seem fix the issue, except now the satellite connected devices lose wifi every few minutes (more often than before). Sometimes my phone connects automatically after couple of minutes. Sometimes it doesnt connect at all. When I try to connect mannually from phone, it fails to connect. One time I saw phone complaining "authentication error".
Before I left this morning I connected satellite with ethernet. I will check how it works once I am back to home.
Are there any debug tools (on phone or router/satellite) to see what is the actual issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can collect debug logs from Satellite IP address\debug.htm. However you'll have to read the logs to see if you can pick out anything.
Might be time to ask NG about an RMA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the management console you can find some information indicating connection status of the satellite to the base router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue with current unit and prior TWO units that were returned. This is not an isolated issue. It has been happening for months.
Netgear: Where is the fix, not a workaround? Did not expect this from Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have done this several times and no improvement with this.
I also tried to separating SSIDs for 2.4 & 5ghz bands. It was ok for a day. Then again problem comes back.
The problem is with Satellite. Router seems okay. If I turn off satellite, things are okay. But then why do I need mesh router?
I am going to give support call to netgear and see what they gonna say. I will update their conversation here later.
Thanks to all for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see there is newer FW out and availble for the 40 series Orbi. Something you might want to give a try:
Let us know if you notice any changes.
