Orbi WiFi 7 RBE973
Reply
RBK53v2 Wifi connection issue in room with router
Sonny455
Follower
I'm having WiFi issues in the room that has the router in it..but when I am in other rooms of the house, WiFi connection is alright..why am I having WiFi connection problems with the router & not the satellites?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Mstrbig
Master
Re: RBK53v2 Wifi connection issue in room with router
Did you turn off WIFI on the router next to your Orbi router?
Message 2 of 3
Guru
What kind of issues are you having while near the RBR? Need more information regarding this.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Has a power OFF of the RBR and RBS for 30 seconds since last FW update been performed?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 331 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
