- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR 40 Issues with green ring
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had the Orbi RBR system for 2 1/2 years and it just fell off my network. I could get nowhere with it and had a buddy mess it. After multiped it.le attempts of loading firmware, it finally accepted it. I connected it back and it worked for two days. Now when I restart it - pulsing white ring, then eventually a solid green ring light. What does a green light mean? (On the top, not by the power button.)
I can't connect to it by ethernet or wireless now. Reset doesn't help.
btw AT&T U-verse if that matters
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR 40 Issues with green ring
Regarding your modem:
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-an...
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Disconnect the RBR from the modem and press the reset button in back for 15 seconds then release. Wire connect 1 PC to the back of the RBR and See if you can access the setup page at 192.168.1.1 using a web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply.
I can not connect to it with a wire. I have pressed the reset button and held for a minute. I cannot connect with a wire whether or not it is connected to my modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to contact NG support and ask for help and information regarding this. RMA if thats an option.
Good Luck.
@harpandiesel wrote:Thank you for the reply.
