Orbi WiFi 7 RBE973
Reply
RBR 50 Continuously Losing Connectivity
enewbauer
Guide
TL;DR: My RBR50 will not maintain a connection to the Internet, even though the wifi stays active. Problems just started a few days ago after over a year with no issues. The problem is the same when I have my laptop connected directly via an Ethernet cable.
Products: RBR50 (RBS50 and RBW30 satellites)
Firmware(s): issues are happening with both v2.3.5.30 and 2.5.1.8; currently running 2.3.5.30)
Hi - I've been having a ton of issues with my RBR50 over the last week. I installed the product in late 2018 and have had virtually no problems since then. That changed five days ago, wherein I started to have a ton of issues with connectivity with no specific trigger (no config change, HW change, etc.) I tried swapping out the modem, now using a Netgear CM1000, but the problems have gotten drastically worse over the last 2-3 days. It's basically not able to maintain a connection with the Internet.
The wi-fi stay active, and in some cases, if I were on a video conference or watching a movie, that will continue to play, but then trying to access a new web site fails and says there is no Internet connection. If I check the app, it says that it's offline. A simple reboot fixes this, but not for long.
I've tried it both with wi-fi and Ethernet cable; same issues.
I had upgraded to v2.5.1.8, but then saw on the forums that people were having a ton of issues with that firmware, so I downgraded the satellites (before the router), then downgraded the router back to v2.3.5.30. No change in behavior.
When I've tested directly with an Ethernet cable coming from the cable modem, I have no issues. So, it definitely seems to be an issue with the Orbi router.
Happy to share any other details or test anything to help diagnose. But, I've put multiple days into this and am about to just go purchase a Google Wi Fi setup and ditch the Orbi platform altogether.
Any ideas?
Thansk,
Mark
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 31
Guru
Re: RBR 50 Continuously Losing Connectivity
Factory reset and setup from scratch...
Message 2 of 31
enewbauer
Guide
Sorry for the delayed response and thank you for these ideas. I implemented the changes you recommended and will see how it goes for a few days.
I'm also going to try swapping out the modem, again, to see if that is part of the problem. While this would be the second modem swap in a week, as I initially thought that was part of the problem, perhaps it wasn't and maybe the new modem is introducing a shakiness that the Orbi does not react to well.
Message 3 of 31
Guru
Sounds good. Please leave feed back to the questions presented as well. Gives us some idea of your configuration.
Message 4 of 31
kilroy818
I'm having the exact same problems as you've described, and in a very similar timeframe. @enewbauer,  if you tried these troubleshooting steps, would you mind reporting back as to whether or not any of them provided relief?
Thank you!
Message 5 of 31
Guru
https://community.netgear.com/t5/Orbi/Orbi-RBR50-instability-issues/m-p/1881887/highlight/true#M8623...
Thank you!
Message 6 of 31
enewbauer
Guide
So, I would say it's sort of fixed. I'll list my settings below and it had been stable for 5+ days. However, this morning, Internet access from some devices was down, yet the speedtest worked AND I was able to access the router via Remote Management through the App (when I was NOT on the network). The only change I made yesterday afternoon, randomly, was enabling Circle for one of my kids' devices. So, I don't know if maybe my modem (set to bridge mode) rebooted in the middle of the night OR if Circle had something to do with my issues this morning.
One item that may be obvious is that make sure when you reboot you reboot everything: router and all satellites. I didn't do this with earlier troubleshooting and I noticed it seemed that things were being persisted unless I unplugged everything and then brought it back online one at a time.
Here are my settings, happy to change anything else if I missed something:
House Size: ~3,000 sq ft
System: RBK50 (FW v2.3.5.30), RBS50 (FW v2.3.5.30), RBW30 (FW v2.3.5.6)
Channels: 2.4GHz - 1; 5GHz - 48
Wifi Neighbors: a bunch, but on different channels
Beamforming: Enabled
MIMO: Enabled
WMM: Enabled
Armor: Not Activated
Circle: Disabled
Daisy Chain: Disabled
Fast Roaming: Disabled
IPv6: Disabled (I believe)
Coexistence: Enabled
Preamble: Automatic
I did NOT do a full factory refresh when I made these changes, but again, the system was stable for 5+ days...until last night when I also happened to enable Circle again.
Message 7 of 31
SW_
Prodigy
Prodigy
@enewbauer wrote:
So, I would say it's sort of fixed. I'll list my settings below and it had been stable for 5+ days. However, this morning, Internet access from some devices was down, yet the speedtest worked AND I was able to access the router via Remote Management through the App (when I was NOT on the network). The only change I made yesterday afternoon, randomly, was enabling Circle for one of my kids' devices...
Circle + DNS could be the culprit.  Check out this thread for DNS issue that many people facing with Circle.  You can try disabling Circle until a fix is available if that's an option for you.
Message 8 of 31
Guru
If are you are noticing problems with Circle enabled, I would post about it over in the Circle forum to let others know about it:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thankl you for posting.
MIMO: Enabled
WMM: Enabled
Circle: Disabled
Preamble: Automatic
Message 9 of 31
enewbauer
Guide
@SW_ thanks for the lead on that other thread; that sounds exactly like the problem that I had at the start of this: I would be on an all day video conference for work, and it would work while other connections would drop, etc. Also - right around the same time. I see you're on that one as well so I'll post some follow-up questions to that thread.
@FURRYe38 I'll post my issues on that board as well. Circle is not a must have for me right now, so I'll keep it disabled for a bit and maybe try enabling in a week or two to see if it causes a disruption.
Message 10 of 31
kilroy818
I also guessed that Circle might be the culprit, based on some of the replies I've been seeing on here, so I disabled it last night. I'll report back after some observation.
Message 11 of 31
Guru
Let us know how it goes. Others have been reporting not seeing any more issues after they disabled Circle.
Message 12 of 31
kilroy818
Well, that didn't take long: I lost connectivity within minutes of posting that reply about having disabled Circle. Rebooted the Orbi and voila, back online.
Message 13 of 31
Guru
Whats the mfr and model# of your ISP modem the router is connected too?
Has a factory reset been performed since last FW update?
How was your last FW update applied? Download of FW files or auto FW update push from the NG services?
If via Auto update, you might download the RBRs FW file, manually apply the FW to the RBR, factory reset. Power OFF the ISP Modem for 30 seconds then back ON. Wallk the setup wizard on the RBR and be sure not to enable any Circle or Armor.
See if this helps any. You might downgrade FW as well to v30 and see using same process.
If nothing seems to help solve this, I would get ahold of NG support about this.
Message 14 of 31
kilroy818
It's a Technicolor TC8717T, from Spectrum. The Orbi and this modem were working just fine and dandy with one another until just a recently. (When did 2.5.1.8 come out?)
No, I have not yet done a factory reset. That's next. I've been loathed to do so, in case it creates any issues with our devices. (It shouldn't if I use the same network name and password, I know, but that's not the kind of luck I have.
The firmware came down through the Orbi app. I never manually downloaded anything. So, yeah, I see what you're suggesting RE: manually downloading and reinstalling the firmware, but I also see "factory reset," which brings me back to the point I made above.
I've read numerous posts about folks who've downgraded only to find the problem persists, so I'd rather not do that until I do the factory reset. I'll most likely pull that trigger this afternoon. Just need to find a good time to kick everyone off. 🙂
Message 15 of 31
Guru
Your modem already has a built in router and wifi. What mode is the modem working in? Bridge or router mode?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option 1 first if you can.
You can save off a current backup configuration to file, then do the reset and setup from scratch. This is a time savor. Be sure to not enable Circle or Armor. Cicle is causing problems. However if you have Circle enabled and re-apply the backup file, then circle maybe re-enabled. Unless you disable Circle first on your currnet configuration, then do a backup to file. Then you would be good to try the back up file after the reset.
12/19/2019 is when v.1.8 was released. I may have not been auto pushed till later for some.
It's been solid for me and others. However I don't use Circle or Armor. These seem to clog up the system. As others are now posting that there problems are being solved by disabling of Circle after they had it running and seeing problems with it.
Message 16 of 31
kilroy818
The wifi is already disabled on the modem, but you're right RE: the double NAT. I'm currently using the other LAN ports on the modem, in front of the Orbi, so I don't think I can go bridge. I did switch the Orbi's IP from DHCP to reserved IP, so let's see if that works.
Thanks for your help. I'll let you know.
Message 17 of 31
Guru
Ok well, if your keeping the modem in router mode I would set up the modem as suggested in option #2. Use the DMZ or IP Pass thru on the modem for the RBR in router mode.
You could use the LAN ports on the RBR if you wanted to bridge the modem. If you needed extra LAN ports besides what the modem or RBR has, you could install a non managed non green ehternet switch behind the RBR to add more ports. This would be preferred.
Switches come in 5 to 48 ports.
What do you have connected to the modems LAN ports besides the RBR?
Or lastly, keep the modem in router mode and configure the RBR for AP mode...
Message 18 of 31
UnCapitano
Apprentice
I'm starting to wonder if this has more to do with the CM1000 that many of us are running.  I swapped out the Orbi system,for an Asus mesh system, and am still getting the intermittent dropped connection.
Message 19 of 31
Guru
Have your ISP check there logs for any drops they may have noticed.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Mines connected to a CM1100.
Message 20 of 31
Hsrancourt
Tutor
Hi- I am having the exact same issue as the original post. Everything has been working fine until a week ago. Our WiFi internet connectivity goes down daily and I keep having to reboot the Orbi which ends up fixing it. The whole time our modem from Spectrum never loses internet. My Mac is wired to the router and seems to maintain occasional partial connectivity . My Orbi app always states that it is having trouble locating RBR50 when the internet connectivity is lost, even though my WiFi shows it still connected to the router network. We do not have Circle enabled. (Never have) we do have Armor enabled. No other setting have been changed since original install. Our Satellite has randomly been going offline as well.
Message 21 of 31
UnCapitano
Apprentice
I turned off Armor on mine because of that exact issue. I didn’t run either Circle or Armor.
Circle worked for me early on before the 2.5.1.8 update, but I turned it off after a while because I didn’t want to pay the subscription. Armor gave my network problems from the start, so I turned it off and haven’t had any problems since.
I’d suggest trying to turn it off, rebooting the router and then seeing if it works better for you.
Rob
Message 22 of 31
Guru
I would change the SSID name to something different instead of using default SSID name. Can be anything. Make it intuitive and fun.
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Message 23 of 31
john442
Tutor
It's the Circle/Netgear integration.  PERIOD.
I've spent literally hours on this.  Its having Circle enabled.  I have the latest FW on my Orbi 2.5.1.16.
With Circle enabled, tons of internet drops between router and my Charter modem.
I've verified with Charter its not on their end.
I have an EXTRA RBR50, and tested it during an "outage"  with no Circle enabled...connected right up, put back the RBR w/Circle NO INTERNET.   Disabled Circle on the original router and everything works (except Circle of course).
With Circle 2-3+ drops EVERY DAY.  With Circle Disabled  -- ZERO over the last 10 days+
My kids are rejoicing at the lack of Circle and I lament the $5 spent on something broken.
I have a support case open with Netgear and I encourage everyone who has it to open one.  Maybe  few hundred cases will get this issue some priority.   Other than this my Orbi works great.
Here are the steps:
  1. Visit NETGEAR's support site here
  2. Under the heading Contact NETGEAR Support, select Get help on my NETGEAR Product.
  3. Then check the I have a NETGEAR product without a serial number option
  4. Select Circle as your product, and enter your most recent subscription renewal date for Circle on NETGEAR Premium (6/16/2020).
  5. This process will get you the best contact info for Circle on NETGEAR support.
Message 24 of 31
Guru
Please post about this in the Circle app forum for your issue:
Good Luck
Here are the steps:
Message 25 of 31
Top Contributors
Discussion stats
  • 30 replies
  • 4488 views
  • 5 kudos
  • 11 in conversation
Announcements
Orbi WiFi 7
