- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR50 Problem
This system is a disappointment, I tried to sign into the community, but can barely stay online long enough to do it. Then, I signed in three times, and immediately receved the message that my session timed out. One of my satellites stopped functioning. I made 5 calls, spoke to 5 different people, and spent over 2-1/2 hours on the phone, trying the same things over and over, until it was finally agreed that my satellite needed to be replaced. On the third call, I started mentioning than my system wouldn’t stay connected to WiFi. Now, I have to reconnect every few minutes. The system worked great for about 4 months, now is barely functional. I googled this problem, and it appears that many have the same complaint. I’ll be fortunate to stay online long enough to publish. We have a larger home, and this seemed to be the best mesh system to cover the square footage. Is anyone in the community having the same trouble? Any solutions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Can you please give use more information about your setup so we can try to help:
- What ISP modem/router are you using?
- Is Orbi in Router or AP Mode?
- What wired and wireless devices do you normally have connected to Orbi?
- What wifi channels are you using in Orbi and how does the wifi radio look like in your surrounding?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Did your original ISP modem have a wireless capability? Is it still there? What is the make/model of it.
Probably a simple solution to your issue, so although frustrating, there is hope.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Thanks for your response.
I have an Arris modem. When I started having problems, Comcast told me I had to be in bridge mode. That didn’t help matters. I got notice this morning that there was a firmware update for Orbi. I did the update, turned off bridge mode on the modem, and changed router mode to MP. Not sure if this is the entire solution, but I’ve been online for over two hours with no interruption. The longest in over a week. Fingers crossed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
What FW is currently loaded?
What is the model# of the ISP modem the NG router is connected too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Great, hopefully that will solve your issues. Please let us knoe how it goes! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Hi @dnh3155
Please be informed that firmware v2.2.1.212 and v2.3.0.32 are now available on our support site
https://www.netgear.com/support/product/RBR50.aspx#download
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Cannot upgrade to firmware 2.2.1.212 which is needed in order to reach 2.3.0.32.
I have 2.2.1.210 and even the dashboard says no new upgrades available. When downloading 2.2.1.212 from official website it stores as a ISO file to be burned onto DVD-R.
Not only is this very cumbersome, but it doesn't work. Tried on two PCs. One doesn't recognise it, the other says ISO file is corrupted!! Please fix and advise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
You only need to download the FW files to your PC, they will come in .zip format. Do not attempt to change the format to anything else. Just unzip the files on your PC, then using the routers web page, navigate to the location where the files were unzip and select the .chk file.
Please use IE11 or FireFox browsers for this. Disable any security browser add-ons before starting this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Thank you so much! I managed it by locating the IMG file and isolating it on the PC where I downloaded it and then browsing manually for it via the Netgear Dashboard. I manually did this for RBR50 v.212 then satellite RBS50, then RBR50 v.032 and again then for RBS50. So four downloads in all but now system is up to speed. Only not sure when the RBW30 will get a firmmware update 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Good to hear. Glad thats working for you.
YA the RBW has a update however some are seeing a problem loading the FW file. Not sure if yours has already been updated or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
I can confirm my RBW30 is still running on V2.2.1.204
So far not seeing improved speeds but hopefully the firmware upgrades will lead to a more stable speed and reception.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
You can try v2.3 and see. You have to manually download and install this file thru the RBWs web page. You can see if you can get it loaded. Users are having problems with the file extension being .chk and the UI is asking for an .IMG file. Some are not having problems.
Let us know what happens if you try this.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
thank you. Experience tells me it is sage to hold back if others are having a dubious experience. I might pluck up the courage someday but rather hope Netgear would make the upgrades smoother. Not sure why the auto updates didn't work this time as in the past. I assume because the latest FW is so new that it only responds via manual upload at this time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Understand.
Yes, I believe NG holds back on auto updates until there maybe more confidence from users as feedback comes in. I think there stance on pushing auto updates in the past can come to bite them some so there offering more beta versions to users who want to test and looking at forum feedback to get a better idea of when the probably turn on AutoUpdate. So Manual updates are good for now. I personally like manual updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Ok, I am a sucker for innovation. So I went ahead with the RBW30 FW upgrade. Pleased to say the chk file was fine and it installed. All items on my network are now at their newest FW.
I think it is wise of them to await feedback this way. I can see the fun of manually upgrading if you know what you do. But the biggest criticism of Netgear from customers has been that upgrades are complicated and adding extra satellites to the network can be cumbersome. Anyway, no complaints here. Cheers!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Good job... I know it felt risky and hope it works smoothly for you. Look forward to your assessment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Thank you Chuck. Happy to feedback in the next few days if any hiccups. If you don't hear from me it is because I am busily surfing LOL.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Thank you for taking the leap. Glad the FW updated well for you.
Let us know if you see any problems with it.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Wire connect PCs to the base to test for speeds first. Then try wireless.
Some older dual core CPUs can't handle some higher speeds like 1Gb. Should be good for 200Mb. I'm using 200/10 here and see to spec speeds on my 11 year old AMD and Mac Book Pro 2008 ON wireless.
@Geo67 wrote:
So far so good. It's too early to confirm whether signal is more stable but in past had some brief dropouts esp when streaming movies from Amazon etc. Also no detectable increase in speed of connection. Apart from a 10 year old desktop PC which manages to get 170mb download via satellite on a 220mb ISP router service most laptops upstairs feeding off same satellite and adjacent that old PC manage just 20mb and usually 2.4khz not 5khz. Even brand new Surfacebook cant get 50mb download. Uploads are never adversely affected. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Problem
Wifi neighbours nearby indeed and most people use the same cable tv ISP.
Do I set the channels in my Orbi (says auto in top right of dashboard but doubt it!) Or do you mean in the Virgin Router of my ISP?
thank you.
