Orbi WiFi 7 RBE973
Reply
Random Ping Spikes
Gnowsone
Follower
Random Ping Spikes
Recently, we have moved to an Orbi mesh wifi system, it works really great getting really good download and upload speeds. However, often when gaming the ping which is usually about 20-30 spikes to about 150-200 for about 5 seconds every few minutes. This gets very annoying and was wondering if there is anything that can be done to help fix it. I have Circle installed and working, but the device used is filed under "Home" so I don't think that it is the problem.
Message 1 of 2
Guru
Re: Random Ping Spikes
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 904 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
