- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replacing RBR40 with RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have had an RBR40 with three RBS20s for about a year now, in a 3200sf home. I have had recurring problems with both satellite disconnects and general loss of internet. It has gotten a bit better with the FW updates, but it is still a regular occurence that I have to reboot the RBR40. The RBR40 is on 2.3.5.30 and the RBS20s are on 2.3.5.26.
Any thoughts on whether upgrading from the RBR40 to an RBR50 would make a difference?
Thanks,
Tom
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Replacing RBR40 with RBR50
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed after last FW update?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
IT would be best to troubleshoot your current setup and narrow down where the issue really is as changing to another different model may only see the same problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the response, Furry. To answer your questions:
*I have a Netgear CM700 cable modem.
*My house is 3200sf/two storeys.
*Two satellites are about 30' from the router, the third is another 30' from the closest other satellite. I have daisy chain enabled.
*I see six neighbors' networks.
*Beamforming, MIMO and WMM were already on.
*I have not done a factory reset since the latest FW update. Is that recommended?
*I changed the 2.4ghz channel from Auto to 6. I changed the 5ghz to 40.
*I turned off 20/40 coexistence.
*I rebooted since making these changes. I'll see if the changes make any difference.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tgarvey wrote:Thank you for the response, Furry. To answer your questions:
*My house is 3200sf/two storeys. Is this a single or multi level home?
*I have not done a factory reset since the latest FW update. Is that recommended? Yes. See odd issues with users continuing to use the system after a FW update. Seems that a reset has resolved most of these kinds of oddities.
*I changed the 2.4ghz channel from Auto to 6. I changed the 5ghz to 40. Are these channels not being used by any neighbors?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a two-storey house. All gear is on the first floor.
I'll do the factory reset.
My neighbors are using 1, 5 or 11. I'm on 6.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
