Orbi WiFi 7 RBE973
Reply
SSID Naming
rugbydman
SSID Naming
Hi. I just got my orbi rbk50. When setting up the system I tried to create the same ssid name as my old system which included a ‘
orbi setup says I can’t use this. So that means all my LIFX lightbulbs and ring doorbell have to be hard reset.
‘Why won’t it allow a ‘
surely this basic stuff
thanks for any help
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 9
Guru
Re: SSID Naming
This an Apostrophy? ( ' )
Maybe some thing NG doesn't support on the Orbi system. i usually don't use specialized characters in SSID names. Maybe a ( - ) dash is all.
You might ask NG support over phone weather they support that character or not.
Message 2 of 9
rugbydman
Re: SSID Naming
if i change ssid i have to hard reset too many things
Message 3 of 9
Guru
Re: SSID Naming
Well for short term, you may have to. If this is something NG may fix, if they do, will take a while.
You'll have to contact NG support about this.
Message 4 of 9
rugbydman
Re: SSID Naming
Hi. Does anyone know if the latest update solves this problem
Message 5 of 9
Retired_Member
Not applicable
Re: SSID Naming
I would doubt it.  NG seems to be more focused on all the cool things people complaint about, like;
back haul
AP mode
Disney/circle
device list
etc.
Message 6 of 9
Guru
Re: SSID Naming
You can try the update and see. I presume it may not. Did you contact NG support and ask about this? You should contact them and ask to see what they say.
Message 7 of 9
rugbydman
Re: SSID Naming
Hi there
them latest update solved this issue. Thanks
Message 8 of 9
Guru
Re: SSID Naming
Good to hear. Enjoy.
Please mark this thread as solved.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1615 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
