- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Some laptops can’t connect to Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Some laptops can’t connect to Orbi
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Were the laptops recentlly updated on there OS?
Esure the latops wifi adapter drivers are up to date.
Other things to try:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Cicada1105 wrote:
Some of our laptops cannot connect to the Orby wireless network. They used to work and now are no longer and we have no idea why. We have turned off the power disconnected the routers and tried that full reset and it still does not work. Any ideas how to fix this?
some?
try resetting the laptop wifi adapter. if some are and some aren't it's probably not the Orbi
