Orbi WiFi 7 RBE973
Reply
V2.3.1.60 streaming
Mordeeb
Tutor
V2.3.1.60 streaming
Just updated to V2.3.1.60 and now PLEX video streaming is total trash. Has anyone else had this issue with the latest firmware? I changed nothing in the router just updated to this firmware and now plex buffers nonstop
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 6
gr8sho
Virtuoso
Re: V2.3.1.60 streaming
I can't speak to Plex, but I have watched streaming video using AFTV with .60 and it works fine. The box is Ethernet hardwired to an RBS50. To me this means the firmware itself isn't the issue. Perhaps something got corrupted during the firmware update. Before doing anything more drastic, have you tried cold starting your Orbi system to see if the problem clears up or is reproducible?
Message 2 of 6
Mordeeb
Tutor
you mean pull the plug and let it reboot?
Message 3 of 6
CrimpOn
Guru
"Pulling the plug" is one way.  There is a "Reboot" option on the Advanced Tab, Advanced Home Page, under Router Information.
Message 4 of 6
Mordeeb
Tutor
did that, everything else seems to stream fine so it may just be the plex server that is hosted externally.
Message 5 of 6
gr8sho
Virtuoso
Yes.
However it seems you’ve determined a different root cause.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1310 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
