kfkchatt
Mar 06, 2019Aspirant
VPN
Cannot get VPN setup. Also remote management reports that my device is offline when i know it is not. Getting Server certificate not setup or something. Support already over with 3 months for a 400+ dollar device.
- Chuck_MMentor
Can you please describe your setup including the Orbi Model #, # of satellites, modem make/model you are connected to, firmware version, etc?
- kfkchattAspirant
I have DDNS already setup. I can connect through android but not through windows client. When i connect to vpn it gives me this.Wed Mar 06 13:43:21 2019 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
- ekhalilMaster
What do you get when you check the status of the DDNS as follows:
- ekhalilMaster
kfkchatt wrote:
....... Also remote management reports that my device is offline when i know it is not. ......
- Are you trying remote management from a browser or from the Orbi app?
- If from browser, is Remote Management enabled under >> ADVANCED >> Advanced Setup >> Remote Management?
- If from Orbi, is Remote Management enabled in the app under >> Menu >> SETTINGS >> Remote Management?
- kfkchattAspirant
When i connect to app on phone. it says connect remotely. when i do my device listed as RBR20 is offline. I know this is not the case.
