Orbi WiFi 7 RBE973
Reply
Which satellite's can I add to an RBR50v2?
jhoff909
Apprentice
Hi,
I have an RBR50v2 and an RBS50 and am looking to add another satellite.  $210 to just add a satellite (RBS50) seems high.  Are there other options?
Thanks!
Jerry
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Which satellite's can I add to an RBR50v2?
Yes, any Orbi satellite except for the new RBS10 will integrate with your Orbi system.  (RBS20, RBS40, RBW30, RBS50Y - expensive!)
If you need WiFi coverage for one specific device that never moves, you could purchase a simple "WiFi extender" for under $50.
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
jhoff909
Apprentice
Thank you!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3538 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
