Orbi WiFi 7 RBE973
Reply
Wired and wireless keeps dropping
colinha667
I keep getting intermittent network drops with WiFi and wired. I just checked the logs and got this:
DoS Attack: ACK Scan] from source: 23.246.6.184, port 443, Sunday, March 15, 2020 21:32:04
[DoS Attack: ACK Scan] from source: 209.148.215.67, port 443, Sunday, March 15, 2020 21:31:40
[DoS Attack: SYN/ACK Scan] from source: 13.225.198.74, port 443, Sunday, March 15, 2020 21:31:34
[DoS Attack: SYN/ACK Scan] from source: 17.248.135.243, port 443, Sunday, March 15, 2020 21:31:27
[DoS Attack: SYN/ACK Scan] from source: 17.248.135.80, port 443, Sunday, March 15, 2020 21:31:27
[DoS Attack: SYN/ACK Scan] from source: 17.248.135.119, port 443, Sunday, March 15, 2020 21:31:27
[DoS Attack: SYN/ACK Scan] from source: 17.248.135.16, port 443, Sunday, March 15, 2020 21:31:27
[DoS Attack: SYN/ACK Scan] from source: 17.248.135.110, port 443, Sunday, March 15, 2020 21:31:27
[DoS Attack: SYN/ACK Scan] from source: 17.248.187.199, port 443, Sunday, March 15, 2020 21:31:27
23.246.6.184 for example seems to be Netflix which is being used right now.
I use Orbi with a Rogers Hiltron Modem which is connected via WAN port. I have also included a screen shot of my statics.
Any Ideas
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 11
Guru
Re: Wired and wireless keeps dropping
What is the model# of the ISP modem the NG router is connected too?
Message 2 of 11
colinha667
Orbi 2.5.1.8
Rogers Internet , hitron modem-CODA 4582
(In bridged mode)
Message 3 of 11
Retired_Member
Not applicable
another case for Orbi 2.5.1.8.....bad FW
Message 4 of 11
Guru
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
@colinha667 wrote:
Orbi 2.5.1.8
(In bridged mode)
Message 5 of 11
Retired_Member
Not applicable
@colinha667 wrote:
Orbi 2.5.1.8
(In bridged mode)
Smiley Sad
Message 6 of 11
colinha667
I’ve actually noticed this started occurring after the firmware upgrade!
Message 7 of 11
colinha667
The distance is good between the router and sat
This is occurring with wired (RJ45) as well. I have noticed this started to occur after the latest firmware update.
I have not tried a factory wipe yet.
Message 8 of 11
Retired_Member
Not applicable
revert back to the previous FW
Message 9 of 11
Guru
Try a reset and setup from scratch.
Message 10 of 11
Retired_Member
Not applicable
and stay away from 2.5.1.8
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1201 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
