Orbi WiFi 7 RBE973
Reply
rbk40 WOL via internet not working
tleung927
Tutor
I was use D-Link and asus router before and i can make the WOL working easily (set the reserver IP and port forwarding ) but after i move to new house i need a better range router. So I choose Orbi RBK40 everything is working fine, except i need to open my PC (192.168.1.2 ) via internet for work, but I can't make the WOL working on RBK40.
2.JPG3.jpg4.jpg5.jpgHere are some setting i made , is there something else  i need to do?
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 16
Accepted Solutions
tleung927
Tutor
Re: rbk40 WOL via internet not working
OMG it's working finally but not by port forward.
I am using router build in VPN + openVPN +  tool in windows call wakemeonlan. Everything is working now even though i am not able to make it work on iOS. I try all the WOL app + openVPN on my iphone but nothing works so far. Anyway thanks for you help.
Message 16 of 16
All Replies
tleung927
Tutor
Anyone?!?!
Message 2 of 16
Guru
I don't use WOL however as a work around, connect up one of the other Mfr routers and use them as your WoL router. Connect up the Orbi router in AP mode and be sure to disable any wifi radios on the other Mfr routers.
What model routers were these other routers?
Message 3 of 16
tleung927
Tutor
I use tp-link ac3200 and T-Mobile asus router before .unforturnaly , i has sold and return them already so that is not an option for me
Message 4 of 16
Guru
You mentioned a D-Link router before, was this a typo?
@DarrenM
Message 5 of 16
DarrenM
Sr. NETGEAR Moderator
Have you tried to make 2 separate entries for port 7 and port 9?
Message 6 of 16
tleung927
Tutor
Yes typo sry
Message 7 of 16
Guru
Remember to disable uPnP after you set up any Port Forwarding configurations...
Message 8 of 16
tleung927
Tutor
I try that too not working either I even try port trigger instead of forwarding still not respond
Message 9 of 16
tleung927
Tutor
disable uPnP  is not helping
Message 10 of 16
DarrenM
What modem are you using and are you using DDNS or do you have a static IP from your ISP?
DarrenM
Message 11 of 16
tleung927
Tutor
I am renting charter modem not sure what brand and modem. But I am using same modem before and WOL works so I think the problem is on router
Message 12 of 16
DarrenM
is it a modem only or does the charter one have a router built into it?
DarrenM
Message 13 of 16
tleung927
Tutor
It’s modem only
Message 14 of 16
tleung927
Tutor
I even try change the subnet mask to 255.255.255.128
still not working .... holy xx i am thinking return this
Message 15 of 16
tleung927
Tutor
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 4626 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
