- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
which Orbi set should I use? (distance >100ft)
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello!
I am replacing my wifi system and considering to use Orbi!
I have a shed where I want to have a satelite. It is 100ft away from my base. and a wall between. I suppose this will not work well.
I have a LAN cable from my base to the shed.
How can I use Orbi to have the satelite in the shed working?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think you should be able to use the same SSID as Orbi. The roaming might not be as seamless as between Orbi router and satellite, but your devices should switch when you go out to the shed.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: which Orbi set should I use? (distance >100ft)
Probably best to use a simple wireless access point in the shed and connect it via wire back to the house. Maybe you can set your old router to AP mode and move it out to the shed. Lower the WIFi output power so it doesn't interfere with the house WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the feedback.
If I use my old router (Apple Extreme) as new Access Point in the shed, connecting it over a wired connection, could I use the same SID as the one I use with the new Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
