leohamel
Apr 15, 2022Tutor
GC728XP is not working after power outage
HI all
I have this GC728XP switch1, its working great except when the power goes out it will not work
you can only see the led on but nothing is connected like there is no switch
the log is not showing anything or maybe i dont know where to look
any ideas?
thanks in advanced
- DaneANETGEAR Employee Retired
- leohamelTutor
its connected directly to power outlet yes
FW is 1.0.5.22
the thing is, this switch is connected to another switch via trunk port
when we restart them both or the power goes off for both, this switch will not connect to the trunk unless we restart it again
it could be some setting on the trunk ports?
will update the FW tonight
