Reply
GS316EP weird vlan behaviour
tmueko
Follower
the switch is connect on port 1 to a HP Pro-Curve-Switch-2510G-48 with pvid 222 and some tagged vlans.
I set up the GS316EP the same way: pvid 222 and the other vlans tagged.
with a static ip, i got 3 pings back one with each vlan:
[2.4.4-RELEASE][root@thegates.kommunity.net]/root: tcpdump -nn -e vlan -i igb13 | grep 192.168.222.235
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on igb13, link-type EN10MB (Ethernet), capture size 262144 bytes
12:57:38.196426 00:60:e0:63:75:fe > 6c:cd:d6:c3:f4:44, ethertype 802.1Q (0x8100), length 102: vlan 222, p 0, ethertype IPv4, 192.168.222.254 > 192.168.222.235: ICMP echo request, id 56180, seq 0, length 64
12:57:38.198799 6c:cd:d6:c3:f4:44 > 00:60:e0:63:75:fe, ethertype 802.1Q (0x8100), length 102: vlan 100, p 0, ethertype IPv4, 192.168.222.235 > 192.168.222.254: ICMP echo reply, id 56180, seq 0, length 64
12:57:38.199329 6c:cd:d6:c3:f4:44 > 00:60:e0:63:75:fe, ethertype 802.1Q (0x8100), length 102: vlan 182, p 0, ethertype IPv4, 192.168.222.235 > 192.168.222.254: ICMP echo reply, id 56180, seq 0, length 64
12:57:38.199799 6c:cd:d6:c3:f4:44 > 00:60:e0:63:75:fe, ethertype 802.1Q (0x8100), length 102: vlan 222, p 0, ethertype IPv4, 192.168.222.235 > 192.168.222.254: ICMP echo reply, id 56180, seq 0, length 64
The switch is set up using dhcp:
here is the log from one of the dhcp-server. the ip 192.168.0.135 is from another network with an own dhcp-server
Sep 22 12:40:44 thegates dhcpd: DHCPDISCOVER from 6c:cd:d6:c3:f4:44 via igb13.142
Sep 22 12:40:44 thegates dhcpd: DHCPDISCOVER from 6c:cd:d6:c3:f4:44 via igb13.182
Sep 22 12:40:44 thegates dhcpd: DHCPOFFER on 10.231.182.246 to 6c:cd:d6:c3:f4:44 via igb13.182
Sep 22 12:40:44 thegates dhcpd: DHCPDISCOVER from 6c:cd:d6:c3:f4:44 via igb13.222
Sep 22 12:40:45 thegates dhcpd: DHCPOFFER on 10.20.30.152 to 6c:cd:d6:c3:f4:44 via igb13.142
Sep 22 12:40:45 thegates dhcpd: DHCPOFFER on 192.168.222.164 to 6c:cd:d6:c3:f4:44 via igb13.222
Sep 22 12:40:47 thegates dhcpd: DHCPREQUEST for 192.168.0.135 (192.168.0.20) from 6c:cd:d6:c3:f4:44 via igb13.142: wrong network.
Sep 22 12:40:47 thegates dhcpd: DHCPNAK on 192.168.0.135 to 6c:cd:d6:c3:f4:44 via igb13.142
Sep 22 12:40:47 thegates dhcpd: DHCPREQUEST for 192.168.0.135 (192.168.0.20) from 6c:cd:d6:c3:f4:44 via igb13.182: wrong network.
Sep 22 12:40:47 thegates dhcpd: DHCPNAK on 192.168.0.135 to 6c:cd:d6:c3:f4:44 via igb13.182
Sep 22 12:40:47 thegates dhcpd: DHCPREQUEST for 192.168.0.135 (192.168.0.20) from 6c:cd:d6:c3:f4:44 via igb13.222: wrong network.
Sep 22 12:40:47 thegates dhcpd: DHCPNAK on 192.168.0.135 to 6c:cd:d6:c3:f4:44 via igb13.222
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 256 views
  • 0 kudos
  • 1 in conversation
Announcements
