masterkik's avatar
masterkik
GS908 smart switch firmware Update
Not clear how to get to Web gui fir smart switch GS908 as ip address mentioned doesn't open page, also does one have to use ethernet cable in switch to update. Also used discovery on WiFi and ethernet cabled to find switch nothing came back
  • michaelkenward's avatar
    michaelkenward
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. In your case, we aren't even talking about a router, the subject for this section.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Discuss Ethernet Switches Plus and Pro Managed
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • masterkik's avatar
      masterkik
      Don't have CD, plus not sure of how to get to Web gui as connected via cable first but ip mentioned doesn't work plus checked underneath device which still didn't resolve issue
        michaelkenward
        masterkik wrote:
        Don't have CD
        That is where the support pages come in. Anything that was on a CD is there.
        The GS908 is an Unmanaged Switch. What tells you that it has any firmware to update? The installation guide says nothing about that.
        Do you mean GS908E? That's not the same thing.
        Did you follow the suggestions in my previous reply?
        Re: GS908 smart switch firmware Update - NETGEAR Communities
ProSupport for Business
