Orbi WiFi 7 RBE973
Reply
Stacking 3x GS752TS steps
DF2002
Tutor
Hi, I have a couple GS752TS and one GS752TSP switches, ready to create a 3 switch stack.
I have 4 sets of the direct attach cables as well.
I have logged into each switch, registered them, and updated to the latest firmwares.
I have assigned the GS752TSP switch a static IP and would like to use it as master.
I have assigned the other two switches static IPs as well. Unsure if this is necessary (or even recommended) if stacking them.
I would like to set them up using stacking in a ring topology.
So what are my next steps?......
Do I use ports 51+52 on each switch to create the ring?
What information do I need to configure in the web interface for stacking on each switch?
I have looked a bit for information or guides but can't quite find info for these models.
Thanks for any helpful tips on where I go next!
Model: GS752TSB|ProSafe 52 ports gigabit stackable smart switch
Message 1 of 4
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Stacking 3x GS752TS steps
@DF2002,
That's great! You may use the DAC cables for stacking and any of the ports from 49-52 can be used for stacking 🙂
John
NETGEAR Community Team
Message 3 of 4
All Replies
DF2002
Tutor
Update: I did find the youtube netgear video which does a nice job of explaining the stacks, albeit with S3300 equipment.
It answered most of my questions.
One thing though, I still am not sure of the exact ports I am supposed to use with the GS752TS equipment. Can I simply use ports 49+50 on each switch using the direct attach cables to configure the stack?
Message 2 of 4
JohnC_V
NETGEAR Moderator
@DF2002,
John
Message 3 of 4
DF2002
Tutor
Awesome, thanks for the confirmation!!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2506 views
  • 1 kudo
  • 2 in conversation
Announcements
