Orbi WiFi 7 RBE973
Reply
VLAN ID limitation?
meinit
Tutor
VLAN ID limitation?
I'm configiring this switch for my network and the existing VLAN i need to connect it to is 100 . In the configuration,
VLAN -> Port Based -> Advanced -> VLAN Identifier .
The VLAN ID goes up to 24. Is there a way to configure the swicth to use a VLAN higher than 24 ?
Model: JGS524Ev2|ProSafe Plus 24 ports gigabits switch
Message 1 of 5
Accepted Solutions
schumaku
Guru
Re: VLAN ID limitation?
For fully flexible 802.1q VLAN config use VLAN -> 802.1Q -> Advanced etc.
Message 2 of 5
All Replies
schumaku
Guru
Message 2 of 5
meinit
Tutor
That did it! Thank you!
Message 3 of 5
schumaku
Guru
Be careful using only the very same entry - using another VLAN "mode" by accident will erase the config in place for another VLAN mode.
Message 4 of 5
meinit
Tutor
Will do, thanks for the heads up
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1822 views
  • 3 kudos
  • 2 in conversation
Announcements
