Orbi WiFi 7 RBE973
Reply
VLAN setup on an IP phone passthrough port
spookz
Hi All,
I am attempting to setup 2 VLANs, one carry VoIP traffic and the other to carry data.  My challenge is each workstation only has 1 ethernet drop, so I am going to need to use the passthrough port on the phones to the computer (ie. [Netgear JGS516PE] <--- Mitel Phone <--- Computer) and I'm wondering if there is a way to have the switch be able to properly segregate the traffic.  My understanding is that the phones can tag their own traffic, but obviously the computers cannot.  Any insight would be appreciated.
Thanks.
Model: JGS516PE|ProSafe Plus 16 ports switch with PoE
Message 1 of 6
Accepted Solutions
Nodism1125
NETGEAR Expert
Re: VLAN setup on an IP phone passthrough port
Hi Spookz,
We have default VLAN 1 port Data Traffic. Since you will connect the PC behind VOIP phone, we need to create a second VLAN and tagged all ports for Voice VLAN and VLAN 1 (DATA) should be all untagged ports.
Example: VLAN 1 (data) and VLAN 2 (Voice)
Advanced 802.1Q VLAN should be set as "Enable".
Mitel Phone,  please configure the VLAN ID to "2" instead of default.
Message 4 of 6
All Replies
schumaku
Guru
You run the VoIP VLAN traffic tagged, the data VLAN untagged.
Message 2 of 6
spookz
Thank you for the info. On the ports carrying these types of traffic, do I flag them as tagged or untagged on the switch?
Message 3 of 6
Nodism1125
NETGEAR Expert
Hi Spookz,
Message 4 of 6
spookz
Got it, I appreciate the clarification.  If I set all the ports to untagged and have the phone tag traffic for VLAN2 (as in your example), I can then setup the router to handle VLAN2 traffic on the port coming from the switch accordingly (DHCP, QoS, etc.), correct?
Thanks again, I'm sure these are basic questions I have just not done this previously.
Message 5 of 6
Nodism1125
NETGEAR Expert
Correct.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 7768 views
  • 1 kudo
  • 3 in conversation
Announcements
