richard6495
May 21, 2018Aspirant
How to encrypt existing hard drives
Hello
I have readyNAS 316 and want to know how I can encrypt my hard drives? They have been in use for last couple of years so have lots of data. I need to do this to be GDPR compliant.
Thanks
Richard
As far as I know, there is no way to do this in-place. You'll need to destroy the current volume and create a new encrypted one (and then restore the data from backup).
- richard6495Aspirant
Thank you very much for your super quick reply
Do you know if I have to do this to be GDPR compliant?
Richard
Do you think I can just create another encrypted volume and then move the data from current volume to this one and then delete the old volume? Or do I have to backup to other external hard drive and then restore it later?
Thanks
Richard
