× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
28T30C7009984 How can I find the wireless password for my NETGEAR?
JDiehl
Follower
Message 1 of 2
Re: 28T30C7009984 How can I find the wireless password for my NETGEAR?
Your Netgear what? Password for what?
Default passwords are on the label on the thing. Anything you, or someone else,  set up is in your of their memory.
If it is lost then reset this device to get it back to the defaults.
It is anyone's guess what you have, but here it the way to fix a router. Most stuff is similar.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
It will also have any software, firmware and drivers for your device.
Look for the model number on the label on the device.
This will explain how to reset the password.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 405 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
