- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
If you mean there is no cable connection betweeon router WAN port and modem LAN port, of course no access to the 'net.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Can I use the AC1750 as a booster?
Reason my cable company gaave me a new router. That was supposted to come with my equipment.
Sort story can I use my AC1750 as a Booster?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Thanks
You should be able to set up a Netgear AC1750 router as a "access point". I'm not sure if that is what you mean by a "booster" or not.
Can you let us know exactly what model number you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Well I got my router Model from the web site by pic.
I have no number on it just went by the color band at the bottem.
Jst wanted to extend my range in house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
It's hard to give you specific info withoug knowing what you have. There should be a product number on the label where the serial number is.
Current AC1750 routers include the R6250, R6300v2, R6400, and the R6700. There is also the C6300 gateway. All have similar shapes.
There are a couple of different technologies here - repeaters, extenders, and access points. They work bit a differently. Most Netgear routers can act as access points, some can act as repeaters. I'm not aware of any that can act as an extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Great, that helps. If it says "R6300v2" then it's a somewhat newer version. If it says only "R6300" it's the original v1.
The manual for your model is here: http://www.downloads.netgear.com/files/GDC/R6300/R6300_UM_18Jun12.pdf
The R6300 can be used as a WiFi access point. It has a "repeater" mode, but you shouldn't use it. It's not secure, and it's limited to 802.11g speeds.
What is the model of your ISP router? We can possibly compare it ot your R6300 and see which has better wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
I received a new Modem, Router from my cable company. I wanted to ust my netgear R6300 As an Booster.Can i if so how?
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Hi @Roadwayws,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Yes I am, cant seem to get it fixed, my log on screen looks different.
I would send you a pic of what I see if I could but cant on this form.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Hi @Roadwayws,
You can attach a screenshot on your reply. Have you tried the suggested steps?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Hi @Roadwayws,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750
Hi @Roadwayws,
Please provide more information. Are you encountering an error? Which part does not work? Have you tried following the steps described on the link below?
Dexter
Community Team
