× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Adding Devices Problem
langelguy
Tutor
I have been having problems with my router connecting to devices.  I read somewhere that these routers connect to 32 devices (each band).  I have many smart devices in my home that need to connect to the router.  This ends up being greater than the 32 the router allows.  Since the devices are only able to connect to the 2.4, having the dual bands doesn't help in this situation. Is there a different router or a simple device that can hold like 50ish devices instead that would be better?  With the current set up I have the devices can't all connect.  Thanks in advance for your input!
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Adding Devices Problem
> [...] Is there a different router or a simple device that can hold
> like 50ish devices instead that would be better? [...]
   You might try adding a (cheap) wireless access point to deal with
some of the Internet-of-junk devices.
Message 2 of 2
All Replies
antinode
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1092 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
