× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connecivity Issues with router WNDR4500v2
Joanne5
Have had this router for two years with no problem.   Now for the past two weeks, every morning there is no internet connectivity.  Every morning I turned modem off then on.    Cable company  replaced modem yesterday.  Thought problem would be solved.    This morning again no internet.       This morning I unplugged router and then plugged it back in....that solved issue and internet came back.   I don’t want to have to do that each time obviously.     netgear  support tells me it must be reconfigured to new modem.  I do have the manual for the router but don’t see directions for reconfiguration.   Please can someone help?
Message 1 of 6
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Connecivity Issues with router WNDR4500v2
Hi @Joanne5,
The steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
Message 5 of 6
All Replies
DexterJB
NETGEAR Moderator
Hi @Joanne5,
1. What is the firmware version of the router?
2. Does the Internet drop for all your wired and wireless devices?
3. Have you tried bypassing the router and checking if the connection straight from your ISP's modem is stable?
4. Have you tried resetting the router?
Dexter
Community Team
Message 2 of 6
DexterJB
NETGEAR Moderator
Hi @Joanne5,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 6
Joanne5
THank you dexter.   When it happens, it affects all devices in the house.    Frequency now is less often than it was.    It happened one time since I started this thread.    How do I reset the router in case I want  to do that?
Message 4 of 6
DexterJB
NETGEAR Moderator
Hi @Joanne5,
Dexter
Community Team
Message 5 of 6
DexterJB
NETGEAR Moderator
Hi @Joanne5,
Any updates?
Dexter
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1736 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
