- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Corrupt firmware, tried reset, can't ping router (WNDR4500/N900)
- Mark as New
- Bookmark
- Subscribe
- Permalink
We had a power outage at our home, after that the N900/WNDR4500 router power light started blinking green which indicates there is a firmware issue. Reseting the router didn't correct, connection to modem shows solid amber indicating it can't connect (same cable works fine for a PC), and I can't ping nor otherwise connect to the router @ either 192.168.1.1 nor 192.168.0.1.
I'm presuming the router is toast/bricked at this point, unless someone here has some alternate suggestions to offer?
Thanks in advance for any help anyone can offer...
Solved! Go to Solution.
Accepted Solutions
![](/skins/images/6B96E1A2051F7650BFB384F7E2B090B1/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/General-WiFi-Routers/Trouble-with-firmware-update/m-p/475334#M48728
read this thread it may help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Corrupt firmware, tried reset, can't ping router (WNDR4500/N900)
Huge thanks searay! Forcing the PC to 192.168.1.2 & using the windows tftp command line utility to force the update worked (the Windows GUI tftp2 tool I downloaded did not, nothing at the GUI level seemed to see 192.168.1.1 as available)
Much appriciate the support and pointer! Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Work!
You're Welcome!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
