- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ethernet Connection not detected
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have this strange situation with my connection. I had an Arris Modem and R6250 was hooked up with that. During a thunderstorm, I saw that there was no power on my router. Sure enough, the AC adapter was dead. I tried hooking up my modem to my laptop via hard wire and no internet connection. So I bought a new modem and power supply for the router. After configuring the modem I was able to get the internet connection on my laptop via hard wire but router kept saying no ethernet connection. I am assuming that the power surge killed the Ethernet ports both on my modem and router? But the strange issue is that I had another (very old) router laying around and that also gave the same error when hooked up to the new modem.
I bought a new router (R6400) and that does work. I just wanted to make sure that the R6250 can not be fixed before I throw it away. Any ideas how to approach this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ethernet Connection not detected
Hi @aj2015,
You can try performing a loop back test to check if the ports are working. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried the loopback test. There are no dedicated LAN LEDs on R6250. The lights below the individual ports (which usually light up when a cable is connected ) did not turn on. Lights for power and wifi on the front are the only ones which are on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
