- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to easily block a device from the network
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can i easily block/disconnect a device on my network, when it is already connected to it?
by useing genieapp i can easily block or unblock a device by "accessing" the network, but when it has already a connection
it does not block it untill de device needs a new connection/stream etc..
router i have is WNDR4500
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to easily block a device from the network
OK thanks for info
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I set up local storage backups on a USB device using my Arlo Pro base station?
You're welcome.
Do not forget to mark the solution.
Have a great day!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You cansend a deauth to that connection and it will force it to disconnect won't it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
How to send this command ? to disconnect a device
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://www.aircrack-ng.org/doku.php?id=deauthentication That should help you out.
