× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
How to upgrade firmware on DM200 with WNR1000v3
Geoff206
Hello All,
I have a DSL Netgear modem (RM200) and want to upgrade its firmware.  I also have a Netgear wireless router (WNR1000V3).  When I go to routerlogin.net, I only see the wireless router.
The router is plugged into the modem and the computer is plugged into the router...
I have seen on other posts that you should be able to access the modem using 192.168.0.1, but that does not work for me.
Any ideas?  Thanks for any help in advance!
Geoff
Model: WNR1000v3|Wireless Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: How to upgrade firmware on DM200 with WNR1000v3
> [...] When I go to routerlogin.net, I only see the wireless router.
   "routerlogin.net" (or one of its friends) generally works if you're
connected directly to the target gizmo.  Which you're not.
   Did you try "192.168.5.1"?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  (Or, look for
"192.168.".)
Message 2 of 3
All Replies
antinode
Guru
"192.168.".)
Message 2 of 3
Geoff206
Thanks! That did the trick.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1675 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
