- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N900 Netgear Wireless Dual Band Gigabit Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a N900 Netgear Wireless Dual Band Gigabit Router. I am trying to connect my laptop and it asks for the pin number of the router. I cannot find one on this router. Does anyone know where I could find it? Thanks, mathpwr
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: N900 Netgear Wireless Dual Band Gigabit Router
Which one? N900 is not a reliable guide to model number. Many devices come with that tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi technologies.
Look at the label on the device for the model number.
Connect the laptop how? Wifi? Wired?
If it is wifi, have you tried WPS? There should be a WPS button on the router. Find the equivalent button in that and press both buttons.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Depending on the model number. the manual should also explain PIN numbers, but you shouldn't need that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you trying to connect using the wps pin number? If so, you'll need to find that in the router gui.
https://kb.netgear.com/31575/How-do-I-connect-to-my-WiFi-network-using-WPS-Wizard
If thats not it, what are you actually trying to do? Use its SSID password?
