× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NETGEAR AC 1200 MODEL 6120 - When connected to router internet speed drops TO 100 Mbps FROM 200
GXRM724
When computer connected directly to modem internet speed is greater than 200 Mbps. When connected to router (NETGEAR AC 1200 MODEL 6120) internet speed drops TO less than 100 Mbps. What can be done to correct this problem?
Message 1 of 4
Accepted Solutions
Guru
Re: NETGEAR AC 1200 MODEL 6120 - When connected to router internet speed drops TO 100 Mbps FROM 200
@microchip8 is exactly correct. You bought a router that isn't gigabit capable.
Its fast ethernet only meaning its connections are 10/100mbps.
You'd need to upgrade to a gigabit router to utilize your speeds.
Or downgrade your speeds and stick with 100mbps.
Message 3 of 4
All Replies
microchip8
Master
Buy a new decent router. The R6120 has only 100 Mbps ports
Message 2 of 4
Guru
Message 3 of 4
GXRM724
Thank you for your prompt informative reply. Have a pleasant day.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1006 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
