- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Please tell me if Netgear R6120 Dual Band AC1200 has the following features
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would like to buy a Netgear R6120 Dual Band AC1200 router. And along with every other feature, I need these two features specifically,
1. Limit speed for a specific IP range
2. Block IP or service for a specific IP range
Can someone please tell me if I should I buy this product considering my requirement?
Also, can you please suggest me any cheapest alternative available of which the mentioned features are supported?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would review the user manual for these features. If you don't see them mentioned, you can presume those are not available on this model router:
https://www.netgear.com/support/
I believe NG does not offer limiting speeds or block for a specific IP address range or a device on most of there routers.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Please tell me if Netgear R6120 Dual Band AC1200 has the following features
@FURRYe38, first of all, thank you for the reply. After you suggested, I just read the user manual, I didn't find anything about the features I am looking for.
Having said that, can you please tell me, if you know, which company's router usually has those features?
- Mark as New
- Bookmark
- Subscribe
- Permalink
People here may know something about troubleshooting Netgear devices. The chances that they are experts in the features of all the hundreds of routers out there are thin. And you won't get anyone from Netgear suggesting an alternative make.
Try talking to one of the retailers that sells different brands.
By the way, the R6120 is a basic and cheap router. It is unlikely to have anything in the way of fancy features. It doesn't even support Gigabit Ethernet, which makes it slower than many modern Internet services.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
