× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
R6020 as second router
ThereseSmith
Follower
I purchased the router thinking I would be able to establish a wireless intranet within an existing wired net. The reason is, I want to support a portable environment for teaching robotics, and the robots are wireless. I started to install the router, as a second router, using instructions at http://www.wikihow.com/Connect-One-Router-to-Another-to-Expand-a-Network
When it came time to access the Netgear AC750, I tried the genie app, which complained about not being able to reach my ISP (which makes sense, because in the wikihow instructions, the ISP is not available.) and then I tried reading the manual at http://www.downloads.netgear.com/files/GDC/R6020/R6020_UM_EN.pdf, and it appears to me that the AC750 R6020 will not permit configuration unless an ISP is available. I hope I am mistaken. Please tell me whether I can access the router without having the ISP on hand, and if so, how.
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: R6020 as second router
Hi @ThereseSmith,
You may find the link below helpful when accessing the router UI to configure it manually.
http://kb.netgear.com/app/answers/detail/a_id/980
If you are looking to set it up as an access point, the link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/24104
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @ThereseSmith,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @ThereseSmith,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 7855 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
