Vietpride218's avatar
Vietpride218
R6020 won't work, in particular Genie by the look of it
Recently got second-hand a R6020 router, which I had to then factory reset. Easy enough. After setting up, I was asked if I wanted to update to 1.0.0.34, which I accepted, which has now led to my current problems. At first, I was unable to load, and went to set up everything in Genie, which is where the problem appears to lie currently. After doing the first page of setup, I reach the second page, with the summary, as well as two buttons, which are print, and next. Only problem, the next button never appears, leaving me unable to complete the setup. I have factory reset numerous times (hold for 10+ sec until all the lights flash green) to no avail. I also have been unable to downgrade due to being rerouted from other sites to routerlogin.net, which is a dead end as stated with the next button not loading. All the lights on the actual router are solid green.
Update: Still will not work, and I have tried on Edge, Firefox, and Chrome with adblockers off.
  • Vietpride218's avatar
    Vietpride218
    Sep 13, 2018
    Actually have now solved it. Was scrounging around and managed to find a forum saying to access the router through "192.168.1.1", which was different from "routerlogin.net". The next button finally loaded and I was able to proceed to setup.
  • I have two or these currently. I can't duplicate your problem without resetting mine. I fount the Genie to be more trouble than it is worth.
    I would reset again, then just skip the Genie. The R6020 defaults to the settings needed. All you should have to do is set-up your wireless with a personal ID and Passphrase. To do the upgrade, just download it from Netgear and follow the instructions under the Advanced Tab and Administration.
      Vietpride218
      That's a part of the problem. I can't even get to the settings through routerlogin.net.
      • TaterSalid's avatar
        TaterSalid
        Virtuoso
        If you reset the router then go to "routerlogin.net" you should have the option to select "do later" I think.
        If "routerlogin.net" doesn't work try "192.168.1.1"
  • michaelkenward's avatar
    michaelkenward
    Where did that come from? The R6020 should opt for the default IP address. If you have another router on your network, or a modem/router, that could explain why you saw that message.
    It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    • antinode's avatar
      antinode
      Guru
      > [...] At first, I was unable to load, [...]
         "load" _what_?  "unable" is not a useful problem description.  It
      does not say what you did.  It does not say what happened when you did
      it.  As usual, showing actual actions with their actual results (error
      messages, LED indicators, ...) can be more helpful than vague
      descriptions or interpretations.
      > [...] and went to set up everything in Genie, [...]
         Which "Genie"?  Ever helpful, Netgear uses the name "Genie" for more
      than one thing.  Netgear routers have a web-browser interface called
      "Genie", and Netgear offers application programs for various
      computers/pads/phones, which are also called "Genie".  I'd stick with
      the web-browser interface.
         Regarding your pictures, at what am I looking?  A Firefox update?
      (Your vision must be much better than mine.  Copy+paste of the plain
      text would be much more helpful than a microscopic picture of the plain
      text.)
      > [...] I can't even get to the settings through routerlogin.net.
         Regarding "can't", see "unable", above.
         Visit http://netgear.com/support , put in your model number, and look
      for Documentation.  Get the User Manual.  Read.  If you have problems
      when you follow the instructions there, then explain clearly what
      you're doing, and what happens when you do it.
      > address. [...]
         Where did _what_ come from?  "1.0.0.34" is a firmware version number,
      not an IP address.
      > It might help if you told people what the modem is [...]
         And it might make no difference at all.  Especially if the problem is
      simply communicating with the router.
        Vietpride218
        Like I said earlier, all indicator LEDs are solid green.
        I was trying to use the web browser interface, like shown in the attached pictures.
        The modem is a Moto MG7310 8x4 DOCSIS 3.0 Cable Modem plus N300 Router. I got the Netgear router due to problems with the two-in-one's wifi (ethernet works well on it). Modem's default IP Address is 192.168.0.1, so not sure if the problem is from an identical IP Address between the Moto and the Netgear.
