- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 and 500 MBPS service.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 500 service with my cable provider. I recently got a new router (R6220) and figured it should be able to take the faster speeds i was going to be getting. After getting installed, i was getting about 370 Mbps and 40 up with the router. I thought i would try without the router and ended getting 577 Mbps and 45 up. SO im guessing the router isnt going to be able to handle the speeds?? Or are there settings i could enable/disable to get things to work properly?
Thanks for any help ahead of time.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @walksonpoo,
1. What is the firmware version of the router?
2. Does the speed issue persist on both your wired and wireless devices?
3. You can try changing the MTU values. Please check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
4. If the issue persists, you can try resetting the router to factory defaults. The steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @walksonpoo,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 and 500 MBPS service.....
Hi @walksonpoo,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Everything was fine after i reset to factory. Still not sure what it was, but it must of been a setting i had on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @walksonpoo,
Thank you for the update and confirmation. Glad to know it is working now.
Dexter
Community Team
