- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 disconnects
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have random disconnections with my device, not much in the beginning but now it's more and more frequent ?
any help would be greatly appreciated . As I look around the community site i have seen that there are other
with the same issue?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Ronald-Lisa-201,
It is possibly a network environment issue if your location has a lot wireless networks that may interfere with the signal. You can still try to re-flash the firmware then reset and reconfigure the router as an isolation step. You can check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 disconnects
1. What is the firmware version of the router?
2. Are all devices affected (wired and wireless)?
3. Have you tried resetting the router?
4. Have you tried changing the wireless channel (if issue is wireless only)?
5. Is the connection straight from the modem stable?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply,
I am having the issues with the wireless, the plugged desk top has no disconnects.
I did reset the router with the tech via support call
the connections a re all good
how do i change the wireless channel ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pages 118, 119 here: http://www.downloads.netgear.com/files/GDC/R6220/202-11443-04_R6220_EN_08Jan2016.pdf
Change "auto" to the desired channel number.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried those items thanks, here is whats still happens. it will connect then drop over and over then it will connect and stay for longer periods ??
- Mark as New
- Bookmark
- Subscribe
- Permalink
We recommend using a WiFi analyzer app /program to check for the best wireless channel. You can use the NETGEAR Genie WiFi analyzer for Android. You can also check the links below.
http://kb.netgear.com/app/answers/detail/a_id/23783
http://kb.netgear.com/app/answers/detail/a_id/24095
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
i waited a while to responed, but the problem is constant, maybe it's overlapping wifi in my building but I tried to change the
channel but it still happens I must reboot every time to get wifi working without the on / off disconnections
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes it's the craziest thing it can go long periods with 7 devices running at the same time then m,ostly on the weekend
it starts the disconnecting and reconnecting i know i live in an apartment bldg with several others with wifi ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have sent you a message. Please check your inbox.
Dexter
Community Team
