- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6250 Wireless Router cuts my hardwired internet connection speeds in half
- Mark as New
- Bookmark
- Subscribe
- Permalink
R6250 - I don't understand... I have verfied (by provider and various speed testes) 100 MBPS when I make a hard wired connection from my modem to my desktop. Then when I switch over to wireless I am at best only getting 50 MBPS. Actually all my wireless devices are running slow the desktop was just the easiest to connect to the modem for speed testing. Any ideas?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @sbhall4060,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
3. Have you tried using a different cable to connect the router to the modem?
4. You can try changing the MTU values. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @sbhall4060,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6250 Wireless Router cuts my hardwired internet connection speeds in half
Hi @sbhall4060,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
