- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6300V2 slow internet over wire
- Mark as New
- Bookmark
- Subscribe
- Permalink
So after performing many tests, I have come to the conclusion that our router favors wifi over LAN connection. I have run a speed test on my phone over wifi and I get a whopping 21mb down while on my computer that is connected via ethernet cable it gets 1mb down.
Is there any way to fix this problem???
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Mitchdojo,
1. What is the firmware version of the router?
2. Please try using another Ethernet cable.
3. Please try using another port on the router.
4. Please check the LAN port status under Advanced > Advanced Home > Internet port box > Show statistics.
5. Does the issue persist on your other wired devices?
6. You can try changing the duplex of the LAN adapter of the computer.
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Mitchdojo,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6300V2 slow internet over wire
Hi @Mitchdojo,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
