- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6300v2 Firmware Version V1.0.3.22_10.1.13SW Firmware update Question
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hardware Version | R6300v2 |
Firmware Version | V1.0.3.22_10.1.13SW |
GUI Language Version | V1.0.3.22_2.1.33.8 |
When I go to http://www.netgear.com/support/product/R6300v2.aspx#Firmware Version 1.0.4.8 it shows that my firmware hasnt been updated since November of last year, so I try to do the "Check" for updates via the router itself, but it says there are no updates available, so I download the update manually and try to Upload it, only to get " THIS IS THE INCCORRECT FIRMARE!" or something to that effect... Am I missing something here?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6300v2 Firmware Version V1.0.3.22_10.1.13SW Firmware update Question
Hard to say. You did unzip the firmware?
Which version did you retrieve. V1.0.3.22_10.1.13SW is pretty old. Did you try something between that and the most recent?
A clearer description of "or something to that effect" might help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it definitely the R6300v2?
I ask because one user thought that the v2 applied to the firmware rather than the hardware. What does the label on the thing say?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
