× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6300v2: restore software/firmware using Android
NetGeek420
Follower
A friend installed dd-wrt and vpn on spectrum router and didn't finish adjusting settings. It has no security and is using one single channel rather than scanning
Model: R6300v2|AC1750 Dual Band Gigabit router
Message 1 of 2
Guru
Re: R6300v2: restore software/firmware using Android
So what are you asking help with?
Removing ddwrt?
If so, you'll want to look on the ddwrt forum for help in removing its firmware. the wrong process can brick a device and they're going to know better how to remove their own firmware than we will.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 672 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
