- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
when trying to acess modem config after reset ....page says must connect to wifi to be able to?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had tried all solutions you mentioned as I had done extensive research on internet.. In the end as I said the only thing that would work was only connect thru wifi with a naked router. Couldn't use ethernet connection to naked router....I try to run a secure setup so my default browser was highly configured that was why I tried browsers that I don't use... to no avail....in the end it was my default browser that connected to gui just with out internet/modem connected. Probably no one else well have identical problem but our discussion may help someone hopefully.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
have tried all methods...i.e. reboot everthing...use different browser...clear cache..etc. same error Can connect to internet, just cant access router management.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
are you trying to connect to the modem or the router?
Router is R6400.
What modem is it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
Hi, the modem is a netgear cm500. Everything was fine till I tried to push WPS button to connect a printer....the router forgot its SSID...so I factory reset it. now it all works with default password....but when trying to access router to change SSid etc. I get message
You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again. it doesnt matter whether im hardwired or connected by wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
> R6400
"R6400" or "R6400v2"?
> when trying to acess modem config [...]
An R6400 is a router, not a modem.
> have tried all methods... [...]
I doubt that, but that non-description conveys no useful information.
> [...] I get message [...]
And your Web search for that message found nothing helpful?
Welcome to what may be the worst error message in the world. For an
explanation, try:
https://community.netgear.com/t5/x/x/m-p/1365830
Briefly, the idea is that "[www.]routerlogin.net" (or ".com") should
point to your own router, but that's true only if you use your own
router for DNS name resolution. Regardless, you should be able to get
to the thing using its IP address, if you can determine (or guess) that.
Normally, that would be something like "192.168.1.1", but it could be
different.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
Here's what I would try to do via ethernet.
1. Reinstall the latest firmware.
2. When it reboots, go to advanced->adminitration->backup settings-> erase. reset it with the reinstalled firmware.
And try to see if this fixes the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
Not sure how to update firmware if I cant get into the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
reset the router with the hardware button.
- On the back of your router, locate the Restore Factory Settings or Reset button.
- Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
- Release the Restore Factory Settings or Reset button and wait for your router to reboot.
After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
Note: The Power light on newer router models lights solid white.
The factory default settings are restored.
After that, reinstall firmware and reset/erase through gui
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
> [...] been there done all that.
Been where? Done all what?
If your web browser is going to that misleading/useless error page,
then your problem is more likely a DNS (or URL) problem than it is a
firmware problem. But without a useful description of what you're
doing and seeing, it'll be tough to guess a solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
Hey appreciate the input....just thought someone else may have had a similar situation.....in the end I had to disconnect the router from the modem and laptop.....factory reset it and connected to the router wirelessly to set it up. Could not do this if it was connected to the modem or laptop with ethernet. I believe it is accessible now and be reconfigured. I am sure I am not as competent as some on this board, but expected the router to behave better after factory reset....never had these issues originally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
After factory resetting initially and connecting to modem it would bring up error even when going to 192.168.1.1....cleared browser caches, tried different browsers to no avail. Most would just get another router but I am persistent believing the router was most likely fine. TWT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
> [...] expected the router to behave better after factory
As already explained, getting to that misleading/useless error page is
generally not a router problem, but a computer/device (DNS)
configuration problem. Accordingly, resetting the router generally
won't change it. Reconfiguring the DNS settings on the computer/device
(so that it uses the router for DNS instead of some outside-world DNS
server) generally will.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
Yes that was the obvious solution, but it would give that error with using 192.168.1.1....why would I need a DNS server then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400
> [...] but it would give that error with using 192.168.1.1.... [...]
That sounds (to me) like a web browser cache problem. If you thrash
around with multiple browsers, different URLs (name, address), and I
don't know what else, then it can be easy to get lost.
For a true test, start with a clean browser, connect the router to
only one computer (not to the Internet), and see what happens. Ideally,
that one computer should be set to use DHCP for everything, including
the DNS server.
If you complicate the system (different DNS server, Internet
connection, too-clever browser, ...), then whole new vistas of potential
problems open up before you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
