- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 to use WNR100 for connecting to security camera
- Mark as New
- Bookmark
- Subscribe
- Permalink
I flashed my R7000 w/ a VPN's access code, wIth the understanding that all devices accessing Internet via my R7000 would go by way of the VPN. The trouble wIth that is, i can no longer get to the original settings/controls for the R7000. When I attempt to log on via a web browser, I get the webpage prepared and flashed onto the R7000 by my VPN provider.
Recently I got an outdoor security camera. I can connect to it via my old N150 wireless router WNR1000 because it operates at the slower speed appropriate to the camera. I don't want to give up my R7000 and VPN functionality. I want to use the old router to connect to the camera, the newer router to connect to the old router, and have the newer router, R7000, connect to the Internet.
The documentation for the R7000 is very poor wIth regard to speaking of "the router" and "the router" without giving me any indIcation of whIch is whIch. I remember settIng up the R7000 the fIrst tIme and having several passwords involved and never beIng sure whIch password was beIng demanded at whIch poInt of the setup procedure. Recently I discovered that "username" is a term applied to the router of all thIngs. It's in prInt so small and so gray on the case that to see it I need a bright light or a magnifying glass.
Are there clear instruction on how to run the older router out of the newer router? If so, where are those instructIons? (When instructIons say "access poInt or bridge" does that mean "access poInt" AKA "bridge"? Or does it mean settIng up an access poInt is one way to do it and settIng up a bridge is another way to do it? If so, what is the difference in the end result?)
ThaNks for your help. (What is with tHe capital lEtteRs tHAt get insertEd inTo my feed on tHIs sitE? It's taKing me twice as long tO type becauSe I hAve tO fix sO maNy miStakEs.) I juSt hAd my own kEyboard rEplAced aNd sO far hAve hAd only prObLems typing hErE.)
WhAt tHE hEcK dOes Hint: @ links to members" mean?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 to use WNR100 for connecting to security camera
> I flashed my R7000 w/ a VPN's access code, [...]
"a VPN's access code"? Whose what? Do you mean that you loaded some
(unidentified) third-party firmware onto your R7000?
> [...] The trouble wIth that is, i can no longer get to the original
> settings/controls for the R7000. [...]
If you replaced the Netgear firmware with some other firmware, then
the Netgear firmware is gone. And complaints or questions about the
(unidentified) third-party firmware should probably be directed to the
(unidentified) third-party.
> [...] I can connect to it via my old N150 wireless router WNR1000
> because it operates at the slower speed appropriate to the camera. [...]
"slower speed"? Do you mean the 2.4GHz radio band? What makes you
think that the R7000 doesn't use the 2.4GHz radio band (regardless of
whose firmware it's running)?
> whIch is whIch. [...]
Huh? _Whose_/_which_ "The documentation for the R7000" are you
viewing? It's documentation for a router. How many R7000 routers have
you?
> [...] I remember settIng up the R7000 the fIrst tIme and having
> demanded at whIch poInt of the setup procedure. [...]
Do you remember reading the R7000 User Manual? (I'd guess not.)
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Types of logins". Further reading might not hurt, either. I'd expect
most of that to apply to your (unidentified) third-party firmware, too,
but you might want to consult the documentation for that, too, whatever
it might be.
> [...] Recently I discovered that "username" is a term applied to the
> router of all thIngs. [...]
Look for "Types of logins" in the User Manusl. Sometimes, reading
the documentation can actually be helpful.
> newer router? [...]
It might help if you explained the actual problem which you are
trying to solve, preferably in terms which make sense to people other
than you.
> [...] When instructIons say "access poInt or bridge" does that mean
Did you look for those terms in the User Manual?
> [...] What is with tHe capital lEtteRs [...]
No idea what you mean.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your kind reply to my nugatory question.
